Yesterday's Tractor Co.
Shop Now View Cart
Re: snapper 1433
08-04-2012 13:03:14
Got er going nice now. Had to take carb back off and give it another cleaning. Running smooth. Took the blade off and gave a nice sharpening. Never been on a snapper before, says 33 inch cut, it really cut even. Thanks so much.
08-04-2012 21:31:56
 Re: snapper 1433 in reply to petermiddletn, 08-04-2012 13:03:14
Way to go! Gives you a real sense of accomplishment, doesn't it? Sounds like you got a real deal there. At one time Snapper was considered to be one of the best.
08-04-2012 14:19:27
 Excellent in reply to petermiddletn, 08-04-2012 13:03:14
Use the second shut off valve.
The needle is supposed to stop the fuel from going into the cylinder then into the crankcase. Sometimes the needle doesn't seat properly. Sometimes the carb has a hairline crack in it but functions ok.
The fuel shut off solenoid is supposed to stop fuel from going into the carb when you turn the key off in order to prevent back firing from a hot engine.
Two telltale signs of gas in the cylinder are it smokes white when first starting and a vapor lock. You will need to change the oil and blow out the cylinder if this happens.
