Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Cub cadet PTO problems
[Return to Forum]
achodges1
07-29-2012 10:16:37
65.69.155.124
I inherited my dad's Cub Cadet 149. Nice tractor but needed some TLC. The Pto clutch lasted about half an hour then wouldn't engage. Upon inspection I discovered it had been worn out for years and readjusted untill the thrust button and fingers were worn away. Installed a rebuild kit, new thrust button, fingers, bearing and springs. Got everything back together and the PTO works as it should. My problem is I can't get the wear button to hold together. First try it lasted about 5 seconds. Took the mount to a machinist had him resurface the face to get a smoothe surface( It had worn away at an angle ).Reinstalled a new button and tried again. Seemed that all was well. It held up at idle and low rpm but at full throttle it gave way again. The wear button surface does not look parallel to the thrust button. Looks like it never has been since new ( mount looks welded crooked ). Could this be my problem ?
[Reply]   [No Email]
stronics
07-31-2012 03:33:02
173.189.168.182
Re: Cub cadet PTO problems in reply to achodges1, 07-29-2012 10:16:37
All that has been said will help for sure but the newer replacment button doesn't seem to be the same material as original ones were. I found an old stock one for mine and was a different ball game.
David
  [Reply]  [No Email]
achodges1
07-30-2012 10:24:50
65.69.155.124
Thanks for the replies. I am going to heat up the arm that carries the button and get it parallel with the clutch. Install one more fiber button and try that. If it fails I'll get one made of something else.
  [Reply]  [No Email]
Bill Lisbon
07-29-2012 19:00:44
69.89.163.149
I bought brass button from a guy on E-bay. Had very good luck with them. Your hole may be worn try a dab of JB weld when you install a new button.
  [Reply]  [No Email]
ray hofstetter
07-29-2012 13:02:18
166.137.88.33
All of the ones I've worked on have been perfectly lined-up....
  [Reply]  [No Email]
ray hofstetter
07-29-2012 13:26:19
166.137.88.48
Re: Cub cadet PTO problems in reply to ray hofstetter, 07-29-2012 13:02:18
Also, is the clutch adjusted properly? If not, it'll eat the button off too.
  [Reply]  [No Email]
wisbaker
07-29-2012 10:19:34
207.118.135.5
There's a wear button on the clutch AND a fiber mushroom shaped thing on the clutch lever do you have both????
  [Reply]  [No Email]
achodges1
07-29-2012 11:52:25
65.69.155.124
Re: Cub cadet PTO problems in reply to wisbaker, 07-29-2012 10:19:34
Yes. It's the mushroom shaped wear button that keeps comeing apart.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
