Part for Walk behind Garden Tractor
Farmallb
Is there a junkyard for old walk behind garden tractors? Im needing a clutch arm rod that goes from down on the drive pulley up to the hand lever. Its on an old Simplicity without gear shift trans.
I kept bending mine on my 2 wheeler, I finally replaced it with a new one made from 3/8 rod. (The old was 5/16) I made my clevis for the pulley end, but they are available from some bearing supply houses.
One other place you can check is Simipletractors.com. They are mainly Simplicity riders, but someone there may be able to help you.
