| Author |
[Modern View]
| Billie R. Smith
07-27-2012 07:36:13
69.245.108.151
With the merger of MTD and Troy Bilt the numbers have all been changed. so i am having a hard time finding a reverse belt for my Pony. I purchased it new in 1984. The belt I need is a #9493. It measures out at approx. 27 1/4 or slightly longer. It is a 3/8 ths.wide belt not the 1/2 that I can find.Also it is a 'V' belt not a flat belt. Are there any good sites to purchase the old stock parts from. :?: Thank you. |
| Billie R. Smith
07-30-2012 16:44:24
69.245.108.151
Re: Old Stock Troy Bilt Parts. in reply to John streets, 07-27-2012 07:36:13
| Quoting Removed, click Modern View to see
I entered that number on the Troy Bilt site and came up empty. I contacted a friend that works at NAPA in Northern Michigan. Is info came back as 9493 replaced by 50134 which crosses over to NAPA part 6679BR. Gonna give it a try. Will take a few days to get the part in. |
| jt
07-30-2012 16:35:02
68.53.181.110
Re: Old Stock Troy Bilt Parts. in reply to Billie R. Smith, 07-27-2012 07:36:13
| Unless I am wrong, that belt is replaced by a GW97075...16.14 through a Troy-bilt/MTD dealer |
| Ronnie Graves
07-29-2012 21:30:59
64.12.116.79
| find a good parts house gates and dayco belts are available in all sizes ( I just bought a belt 1/4wide ultra V ) and my drill press uses 3/8 wide belts never had any problems getting them! |
| Billie R. Smith
07-28-2012 07:24:13
69.245.108.151
Re: Old Stock Troy Bilt Parts. in reply to t.r.k., 07-27-2012 07:36:13
| Please forgive my feeble old mind,and allow me to correct the info I have given.
GAT 6824 is as you have stated 24 inches x 1/2. It is the forward belt. I have replaced that one and it works fine.
The reverse belt is the one I am trying to replace.P/N9493 which is no longer available.I tried a GAT6827 but it was the one that was way too tight.It too is a 1/2 belt. The measurement of the original belt is 271/4 (maybe 27 3/8 ) x 3/8 wide. I apologize for the confusion and hope this new info will help you to help me. Thanks.
Troy Bilt also offered at one time p/n 4922 which is a set of belts for the earlier Pony.
This post was edited by Billie R. Smith at 07:37:38 07/28/12. |
| Billie R. Smith
07-27-2012 19:44:27
69.245.108.151
| [quote="El Toro"](reply to post at 02:25:10 07/28/12) [/quote
I tried a Gates 6824. I managed to get it on but it was so tight that it would not disengage.I actually had to cut it off. What a waste of a new belt.Parts guy said they only come in whole inches,and 1/2 wide.I figger 27 1/2 would be too loose even if I could find one. Problem wiyh the wider belts is they dont set down into the pulley and as such need to be longer. |
| El Toro
07-28-2012 03:53:44
108.3.148.85
Re: Old Stock Troy Bilt Parts. in reply to Billie R. Smith, 07-27-2012 19:44:27
| The 6824 is 1/2" wide and only 24 inches long. See if they have a 3/8" wide and 27" long belt. Hal The second digit is the width. Look at 6627. |
| El Toro
07-27-2012 18:25:10
108.3.148.85
| I would buy a Gates Green Stripe belt from your local auto parts store. I use their p/n 6822 belt on my Horse Model. That belt is 1/2"wide and 22" long. They're about $14.00 and last a long time with all the clutching and declutching. Mine has been on there 6 years. Hal |
| Billie R. Smith
07-27-2012 10:34:55
69.245.108.151
| Thanks. looks like I will be heading to TSC and crossing my fingers. |
| rexbeavers
07-27-2012 09:02:28
72.28.7.127
| i would go to a napa auto parts store a tell them you need a blade runner belt thats 3/8 bye 27 an 1/2 or take your old belt an they can measure it or try a tractor supply store they have 3/8 bye 27 the belt you need 9493 is not available any more |
