TractorLinks.com
Re: Lawn Tractor Brakes
rustyj14
07-20-2012 18:28:37
Take the brake assembly apart (remember how it goes back together. Clean the two plastic pins, lube the metal casting, buy a new brake pad, and reassemble it. Oil it greatly, and make sure when you push the brake pedal that the lever on the brake assembly moves forward and back. that lever has two bent areas that push the little round pins in and in turn, they push the brake pad in to make contact with the brake disc! Most any lawn tractor repair place will have brake parts. Note: There might be a small steel plate inside the assembly, that goes in on top of the brake pad/ block. the brake operating rod should have an adjustment on it, too. Don't worry about getting oil on the brake pad, or anything else. It will keep it operating well. Been fixing lawn tractors for about 20 years. RJ
Larry Hardesty
07-20-2012 20:48:01
 Re: Lawn Tractor Brakes in reply to rustyj14, 07-20-2012 18:28:37
"Take the brake assembly apart (remember how it goes back together. Clean the two plastic pins, lube the metal casting, buy a new brake pad, and reassemble it. Oil it greatly, and make sure when you push the brake pedal that the lever on the brake assembly moves forward and back. that lever has two bent areas that push the little round pins in and in turn, they push the brake pad in to make contact with the brake disc! Most any lawn tractor repair place will have brake parts. Note: There might be a small steel plate inside the assembly, that goes in on top of the brake pad/ block. the brake operating rod should have an adjustment on it, too.
Don't worry about getting oil on the brake pad, or anything else. It will keep it operating well. Been fixing lawn tractors for about 20 years."
Rusty, no plastic parts and cannot find someone who has the brake puck. I put it back together and adjusted it. Works but probably I need to install a go cart brake. Thanks Larry
rustyj14
07-28-2012 08:35:08
 Re: Lawn Tractor Brakes in reply to Larry Hardesty, 07-20-2012 20:48:01
Any lawn mower repair place should have those two little "Plastic" pins, which i said are the only plastic parts in the brake assembly! I did NOT say that there were any other plastic parts in the brake assembly! I don't know what the brake pad (puck) is made of! But, it is NOT plastic! Rusty J.
P.S.: Maybe you should enrich the knowlege of the rest of us, by having the little pins examined by some place that does those things, report back to us, and then we can be literally correct in our descriptions of items! Rusty Jones, The Mower Man
