Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: briggs compression
[Return to Forum]
ira biggs sr.
07-20-2012 18:20:14
66.11.108.155
17.5 hp briggs , vertical shaft, on a cub cadet o turn.17.5 hp ic engine , high performance , model318707 , type 0132-e1 , code0002218ze. the problem i have is when you try to start it and it comes up on compression it wont turn over, it just stops. it has a new battery , rebuilt starter and i jumped from my truck and the same thing.pulled the flywheel the key is not sheared. the valves are both moving.i have never heard this engine run but it is to be ok. thanks for any and all help. pulled the spark plug and it turns free.
[Reply]   [No Email]
Ira biggs sr
07-22-2012 10:55:37
66.11.109.9
 Re: briggs compression in reply to ira biggs sr., 07-20-2012 18:20:14
adjusted the valves and it turns over as it should. i never would have guest. thanks again i learned something today.
[Reply]  [No Email]
ronnie graves
07-20-2012 21:33:41
205.188.117.17
you didnt tell him the secret rotate the engine backwards it un-loads the compression release then set the valves to 0.03
[Reply]  [No Email]
t.r.k..
07-21-2012 17:51:22
71.31.64.233
 Re: briggs compression in reply to ronnie graves, 07-20-2012 21:33:41
Well, actually you don't.
You set the valves with the piston a fraction of an inch down the cylinder past TDC.
That is what the manual says.
Nobody takes the head off one of these engines to set the valves if they can get away with it. The only way to get an idea of where the piston is is to remove the blower cover, rotate the crankshaft until the piston comes up on comression, and then rotate it until the back edge of the magnet is just about past the magneto. At this point the piston should be starting down the cylinder.
Then adjust the valves at this position.
I don't see what rotating the engine backwards will do for you. I don't think the compression release retracts until it reaches about 300 rpm.
[Reply]  [No Email]
t.r.k.
07-20-2012 19:47:21
71.31.64.233
Adjust the valves to .003. The book says .004-.006 but if you set them to .003 and tighten the setscrew you will be at about .004.
I have seen two of those engines that would not hold a valve adjustment for long, both had been run a long time with infrequent or no oil changes, I am guessing that the hard part of the valve lobes on the cam were worn about through and the valve clearance would get out of spec in very few hours run time.
Good luck with yours.
[Reply]  [No Email]
H2OK9
07-20-2012 18:32:47
71.50.17.172
Adjust the valves, They have a bad habit of needing adjustment every so often and it sounds like they have been neglected
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
