Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: ZAMA carb
[Return to Forum]
George Marsh
07-20-2012 13:56:42
50.104.225.241
Working on a 25 cc Weed Eater. It will run fine at 1/2 throttle and 1/2 choke. Running lean if I remove choke or increase speed. There appears to be places where adjustable jets were, even marked L & H, but they appear to be plugged off.
Took carb apart many times and blew it down. No improvement.
What does a person do? Don't have a gun.
George
[Reply]   [No Email]
joe csuti
07-20-2012 17:43:46
70.111.203.118
 Re: ZAMA carb in reply to George Marsh, 07-20-2012 13:56:42
If this carb is built same/similar to most walbro carbs an easily/usually over looked item in carb is the 100 mesh screen filter pressed into a cavity in carb body(I don't remember if it's under pump diaphram or metering diaphram)if this screen gets dirty/gummed up it will make eng run lean or not at all without choke,if carb has screen you can clean by carefully removing same from carb body,soaking in carb cleaner then blow out from backside & reinstall or goto link below & type 38-8121 in search,screens are priced each,but only sold in 10 pack,also while there click on chainsaw & look at zama rebuild kits,see if any for your mod# carb.
[Reply]  [No Email]
George Marsh
07-20-2012 14:43:08
50.104.225.241
Went on line and checked out ZAMA web sight. It says that it requires a special tool to adj the carb and they don't sell the tool.
Any idea where to find the special tool?
[Reply]  [No Email]
rrobert
07-20-2012 15:12:08
71.227.6.189
 small engine shop in reply to George Marsh, 07-20-2012 14:43:08
Might sell the tool. I have seen some that are half moons and others that are splined 12+ points like a torx.
I just used a thin grinding disc on a dremel and cut a slot so I could adjust it with a flat screwdriver.
I couldn't get either carb to work so I scrapped the machine.
One thing you should check is the exhaust. Remove the muffler and see if it runs properly. There is a spark arrestor screen that will get clogged with carbon. Either remove it or clean it.
[Reply]  [No Email]
George Marsh
07-20-2012 16:20:48
50.104.225.241
 Re: small engine shop in reply to rrobert, 07-20-2012 15:12:08
Went to ebay and found the tool for $7.97 including shipping. Ordered one.
[Reply]  [No Email]
rrobert
07-20-2012 22:45:14
71.227.6.189
 forgot to mention in reply to George Marsh, 07-20-2012 16:20:48
Also, check the fuel line inside the gas tank. The fuel line and return line will look fine on the outside of the tank but be rotten/cracked inside the tank. Replace with line from a small engine shop. Don't mix the lines up.
[Reply]  [No Email]
rrobert
07-20-2012 15:14:49
71.227.6.189
 ps in reply to rrobert, 07-20-2012 15:12:08
Be careful with the yellow lever. I broke the last one I worked on and had to patch it back together.
[Reply]  [No Email]
rrobert
07-20-2012 14:06:19
71.227.6.189
 buy a new carb in reply to George Marsh, 07-20-2012 13:56:42
Some of those carbs are cheap($25) to buy new. A diaphram kit is about $12 which is a good idea to install if you are opening it up. The diaphram(fuel pump, round aluminum on it) should be dry on one side and wet on the other. If it is wet on both sides, it is no good.
I can't tell from that pic but I have cut notches in the adjustment screws and tried adjusting it. I can't tell if those are permanent or adjustable.
If it is more than 4 years old, I would cut losses and buy a new machine. The $100 one's from Walmart, Home Depot, Sears and Lowes are disposable. If you get 3 troublefree years out of them, you have done well.
[Reply]  [No Email]
George Marsh
07-20-2012 14:40:03
50.104.225.241
 Re: buy a new carb in reply to rrobert, 07-20-2012 14:06:19
Just trying to fix it for another person..my guess is the weed eater isn't worth $25.
No adjustments on what looks like jets.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
