TractorLinks.com
Re: brake pad
Larry Hardesty
07-19-2012 07:24:38
I will take it off and take it to a local lawn and garden shop. Thanks much.
Bookman
ken combs
07-19-2012 12:35:10
 Re: brake pad in reply to Larry Hardesty, 07-19-2012 07:24:38
Lining material is available from mcmastercarr.com. You can select the thickness you need, shape to fit and apply using the adhesive of your choice. I like 5 min epoxy, others use contact cement.
rustyj14
07-20-2012 18:34:33
 Re: brake pad in reply to ken combs, 07-19-2012 12:35:10
Warning: If that brake has the rectangular fiber brake pad, and two little pins, DO NOT GLUE IT TOGETHER!! It will not work! RJ. SHEESH!
Larry Hardesty
07-20-2012 20:52:06
 Re: brake pad in reply to rustyj14, 07-20-2012 18:34:33
"Warning: If that brake has the rectangular fiber brake pad, and two little pins, DO NOT GLUE IT TOGETHER!! It will not work! RJ. SHEESH!"
RJ, Nope, nothing like that. Just two metal brake pucks (one on each side of the about 2.75 inch diameter disc.
Larry
