Yesterday's Tractor Co.
Shop Now View Cart
Re: Do you have pictures?
Larry Hardesty
07-19-2012 07:22:59
They are disc brakes...not expandable drum brakes. The pad is worn and does not fully connect to the disc. The disc is only about 3-4" in diameter. Kind of wonder how well they worked when new?
Sorry, no pictures.
I will try local shops for ideas. Might have to go to a go cart brake.
07-19-2012 08:01:56
 ok, if what I think in reply to Larry Hardesty, 07-19-2012 07:22:59
The pads should be about 1/4" thick.
There is pad on the transmisison side, then the disc, then another pad, a thin piece of sheet metal, and then 1/4" two pins inside the outer cover. A lever connects to the center of the outer cover. When you move the lever, it pushes on the pins and forces the pads together. The pins are known to rust in the aluminum cover. the cover is held on with two 3/8" bolts. Remove cover and loosen pins up. The center nut that holds the lever can be tightened to put more pressure on the pads.
To avoid breaking the 3/8" bolts, you might be able to remove the center nut and lever in order to free up the two pins.
Larry Hardesty
07-19-2012 08:43:11
 Re: ok, if what I think in reply to rrobert, 07-19-2012 08:01:56
Robert, kind of the right principle but not exactly what I have. I think I will take it off and go to a local lawn and garden tractor shop. I suspect I will end up replacing it with a go-cart style brake. If the chain ever breaks or comes off the sprocket while going down hill, it could be quite a ride!!!
