TractorLinks.com
Re: bs stalls under load -was the solenoid
kouvakis
07-18-2012 17:00:08
thanks guys, found out what was wrong. the carb bowl solenoid that lets fuel into some where was no getting power when ignition on. jumped from battery positive terminal to white lead into solenoid and runs just fine WUUUUUUUUUUU WHOOOOOO.!!!!!!
Now all a need to know is does the solenoid get power from the muLti switch kill system or directly from ignition switch or other arrangement. i guess i could spend hours working it out but would appreciate anybodys experience or hints. thanks mb , az etc.
rrobert
07-18-2012 19:39:21
 key in reply to kouvakis, 07-18-2012 17:00:08
The ignition switch controls the fuel shut-off solenoid. Use aligator clips until you are able to find and solve the problem.
It might be the plug in the back of the switch is corroded. Clean and try again. Replace if they are rotted.
I am not sure which terminal is for the fuel shut-off. If I were to guess, I would guess it is marked "ACCY" for accessory.
