i have a 2 cyl B&S 20 hp intek twin ohv motor on my husky riding lawn mower. about 12 years old but dont mow very often or lotta space has good compression has been stalling under load of cutter. replaced one spindle with worn bearing on cutter, new belt . removed and cleaned nikki carb. still doing it. need to mow real bad. will start run and travel ok but when engage cutter stalls after 30 sec or minute. would cut about 20 feet then stall. wouldnt start after stall without little gas down intake. after cleaned carb starts better after stall without air cleaner. stalls under load faster with air filter in place. little solenoid at bottom of bowl works on bench test. filling tank up full didnt help any. afte stalls some smoke comes up out of intake when crank with starter. stalls faster at lower accelerator position than higher (mo revs) position.
going to town to get little mower gas filter
have reached end of my expertise. HELP
thank in advance for for your interest
bh
bh
