Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Cub with a Kohler Courage 22
[Return to Forum]
pmer
07-16-2012 14:10:42
166.156.116.29
Are thes engines known for valve troubles?
The mechanic put in a set of push rods and it bent this set too?
[Reply]   [No Email]
ronnie graves
07-16-2012 21:50:44
205.188.117.17
Re: Cub with a Kohler Courage 22 in reply to pmer, 07-16-2012 14:10:42
Just went thru all of that with a 25 ,first retreave your machine before the bill goes thru the roof!
when you get the new pushrods first make sure that the engine is clean wash it down and then pull blower cover and clean some more ,the instructions Im going to give you are from Kohler
they came in the box with the new starter ,telling the dealers that they were having too many warenty returns on starters
first the engine has to cold remove both spark plugs rotate engine CCW backwards from the way it runs (that un-cocks the compression release )2 full turns stoping the left cylender on top dead center thats left sitting in front of the engine
install push rods and back the ajusters off
set the valves on that cyl to 0.005 in and ex
still turning backwards bring the right cyl to tdc and install pushrods and set them the same way ! install plugs and valve covers start engine and check for leaks ,install all other stuff removed !
  [Reply]  [No Email]
pmer
07-16-2012 21:08:24
75.234.103.186
Thanks guys, at the start of this trouble I had the cover off thinking it was a coil and there were no nests then.
It is sad because the 1050 is a year out of warranty and shop has had it forever because pushrods were on back order.
I called them today and learned that the new rods bent in 5 minutes of operation. Now he said they sent the cam out to see if it is bent ... really? I they now what they are doing.
  [Reply]  [No Email]
t.r.k.
07-16-2012 19:50:29
71.31.64.233
When your mechanic put those pushrods in, did he just open the valve cover and stick them in, or Did he take the blower cover off and inspect the fins, especially the area around the cylinder head?
I just put 2 pushrods in a Briggs twin that a mouse had totally insulated the left (#1) cylinder with fiberglass insulation. The overheat condition bent both pushrods on that side of the engine and froze the valves in the head.
  [Reply]  [No Email]
joe csuti
07-16-2012 17:12:40
151.198.126.139
Problem could be caused carbon buildup on valve stems causeing valves to stick,weak/broken valve springs,incorrect rocker arm/valve stem clearance or possibly wrong push rods installed,kohler manual says check clearance between valve spring turns at full lift or push rod bending can occur,min allowable clearance between turns .010".
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
