international 184
fredmich
I lost a bearing while mowing today on one of the idler/tension pulleys that are near the drawbar and tension the belt and lets the belt change directions to go forward to turn the mower. Got on the Case/IH site but couldn't find it. The bearings look like they are replacable and are held in with snap rings. Does anyone have any info. on these pulley/bearings and website that I might find them? This is a 184 with a 60" mower deck. Thanks for any help....Fred
You can replace it with a standard bearing and a shouldered bushing. If you have a Tractor Supply Store, The bearing is 990502H and the bushing SKU 1185382 (Phoenix No. 36375102).
The bushings can be found at most idler pulley sources. They supply stock pulleys and bushings to fit your application. It's a 5/8" to 3/8" shouldered bushing.
The bearing is 5/8" ID x 1-3/8" OD x 7/16" W.
