Yesterday's Tractor Co.
Shop Now View Cart
Cub 125 PTO
07-10-2012 07:33:10
Can the PTO on a cub cadet 125 be rebuilt without taking it off?
07-17-2012 14:33:34
 Re: Cub 125 PTO in reply to RichHielscher, 07-10-2012 07:33:10
The set screws are in 3 different holes spaced around the hub, they are small hex allen wrench, one on top to lock the bottom screw, 6 total. You can then pull the clutch off.
07-11-2012 11:17:15
You need a manual to learn how to get the clutch off unless youalready know how. There is a bearing with a eccentric lock collar that has to come loose.
07-10-2012 15:06:04
You have to disassemble the unit to install the clutch disk. There are 6 set screws that need to be removed before you slide the PTO assembly off the shaft. I would soak the screws with PC Blaster before attempting to un-screw them. It takes a 1/8-inch long handle allen wrench.
07-10-2012 15:26:43
 Re: Cub 125 PTO in reply to jb9959, 07-10-2012 15:06:04
Make sure your set screw heads are clean before you start so you can properly insert the allen wrench fully in the head. If you don't you can easily strip the head and you will have to use a drill to remove the screws and will probably ruin the clutch in the process.
07-10-2012 12:09:28
I don't think so, but you only have to pull the clutch pack and not the basket & pulley.
