Standard Monarch garden tractor
I was give a Standard Monarch garden tractor today and need to know if there is any parts available. Rings, carb, ignition, and a parts manual would be nice. It's ser.# 409E3402. The engine and gears are free and the tractor looks pretty good for it's age.. The tires and wheels are bad but I have steel wheels from a Walsh tractor that will work. Thanks for any help or advise you can give.
Does it look like this tractor? The man that owned this tractor ended up with a bad bruise on his arm when it kicked back. Not sure if he still has it. I had a Viking and about 5 Standardtwin garden tractors. Hal
It does look similar to the picture except for steel handles and it has rubber tires on spoke wheels. I have a set of steel lug wheels like this one I can use on it. I mostly need engine parts if they are available,. Larry
