TractorLinks.com
Re: John Deere 317 PTO doesn't engage
BLH
07-07-2012 09:28:48
Have someone sit in the seat and with the key on, engine off, turn the pto switch on and see if you have 12 volts at the connector where the tractor harness hooks up to the pto clutch. If you do, the clutch could be bad, the air gap needs to be adjusted, or a bad ground at the clutch. Since you said it stopped while mowing, I would lean toward the air gap needing to be adjusted. When the mower cools down, will the pto clutch reengage? If so, that is also an indicator of the clutch air gap being too wide.
