TractorLinks.com
CUB 682
Kevin in MN
06-05-2012 18:06:23
HI,
I have a Cub 682 that will not move. I pulled the rear sheet metal for full access. I can tell thet the pump shaft is turning. I put a gauge on the pressure port and with the lever in full forward I get nothing (no pressure), but once in a wile I get a chatter comming back via the spring thing the lever connects to and the rean wheels turn a bit.
Background, the tractor wouldn't run and sat outside for several years. I recently got it after my father passed away. I ended up replacing to coil to get it going and drove it around and it went great, then all of a sudden it started not moving and then it would work fine for a bit. Fluid looks clear and full. Any Ideas?
Kevin in MN
Kevin in MN
07-17-2012 19:34:19
 Re: CUB 682 in reply to Traditional Farmer, 06-05-2012 18:06:23
Update:
A fluid and filter change and it now drives! Fluid was clear until the end then it turned red. It looked and smells like auto transmission fluid.
R Bedell
06-19-2012 03:22:14
 Re: CUB 682 in reply to Kevin in MN, 06-05-2012 18:06:23
Kevin:
Yeah....that is a pain. As a suggestion, get some small tubing, insert into the Dipstick Tube, say about 12-15". At the top of the tube, bend it off to one side. Then pour your fluid in Dipstick tube. This allows the air to escape. :)
Kevin in MN
06-18-2012 16:35:39
 Re: CUB 682 in reply to Chris Jones, 06-05-2012 18:06:23
Changing the filer gave instant results it now moves. So I thought before getting too far I should change the fluid. I drained it but now having a heck of a time refilling via the dipstick tube. Takes very little at a time and the "burbs" back. The manual doesn't anything specal about refilling. What am I doing wrong?
Kevin
R Bedell
06-08-2012 03:49:22
Kevin in MN:
Here is a link to the recommended and correct Hydro Fluids....... Hydro Fluid
Kevin in MN
06-07-2012 16:56:34
 Re: CUB 682 in reply to El Toro, 06-05-2012 18:06:23
OK, I got a new filter but having a little trouble find correct fluid.
R Bedell
06-07-2012 03:52:07
Kevin in MN:
IF the input shaft to the hydro is rotating when the engine is on, then the second place to look at as mentioned before, is the Hydro Filter. Replace this Hydro Filter.
Kevin in MN
06-06-2012 18:06:42
 Re: CUB 682 in reply to oldtanker, 06-05-2012 18:06:23
I pulled the valves and they were clean and like new. As they are the same I swaped them and no change.
t.r.k.
06-05-2012 19:15:54
Stopped up filter, perhaps?
Release/bypass valves open? (The valves you open so you can push the unit with the engine off.)
