studebakerjim
My LX188 has a both battery and oil light coming on. The will come on and off and not always at the same time.
The unit has a new battery and I have not check the charging yet when running, correct me if I'm wrong, but should I see a 1 to 2 volt increase on the bat. voltage when the tractor is running?
I feel that its one of two things. One a bad wire connection or Two a battery key switch circuit board. I relplaced the board about 6 years ago as it was the prolbem when the mower would just shut down when running.
Any ideas out there? I know it comes down to elemination at this point. Any specs on oil pressure?
Jim
Jim
