This post is a followup to a post from about 6 days ago:
I thoroughly cleaned out the carb on my '97 425 after running poorly. I removed seemingly everything that was plastic or rubber before soaking carb body in Berryman's cleaner. I also removed and cleaned jets, choke shaft, throttle shaft, idle mixture screw, etc. In other words, I removed everything that could be removed, cleaned them, blew everything out with air and re-assembled.
My problem is this: Even though I can see that the throttle plate is closed, I can easily start the engine, but it will race until I shut it off. Moving the throttle lever will open and close the throttle plate properly, but it races like a raped ape until I shut it down(which is immediately).
I tried adjusting the idle mixture screw, even closed it completely, but the engine will still race with the throttle plate closed.
I did replace the gasket between the carb and intake because it was torn. It is not upside down and can really only go on one way. Carb seems to be properly tightened down.
The engine can only race like this if it is getting a lot of air, correct? Am I looking at some sort of leak possibly or?
Thanks for any ideas, the lawn needs a good mowing now!
