Mid 1980s John Deere 185 Hydro with a 540 Kawasaki engine. Electric PTO.
I messed up and connected the battery backwards. It started and ran fine. We used it for about 2 hours like that before I realized the error. Connected the battery correctly. I replaced the 20amp fuse(assuming alt fuse). The battery light is still lit on the dash.
The battery had 12.4 volts before starting. After starting and running, battery voltage kept creeping up to 12.8 after 2 minutes and the battery light was still on. Fuse is ok. Is it charging? Did I ruin the alternator, voltage regulator, ignition, relay or something else?
Any test suggestions? I will take a look at it in the morning if I have time.
Thanks, robert
Thanks, robert
