FORD YT 12.5
Detmurds
I am looking at buying one of these Ford YT 12.5) for a very, very low price,..if the engine is bad, how hard would it be to find a replacement? According to Tractordata dot com, it has a 655cc Briggs & Stratton 2-cyl gasoline in it.
Also,..I would love to hear any comments on this thing if you have any?
The eng for this tractor is nla,even small eng warehouse doesn't have a replacement eng listed for same,IF eng bad without going thru a major hassle trying to install a different make/mod eng in tractor the choice's are either rebuild eng or see if you can find a good used 12-14hp eng on ebay or craigs list.
(quoted from post at 15:57:15 03/25/12) The eng for this tractor is nla,even small eng warehouse doesn't have a replacement eng listed for same,IF eng bad without going thru a major hassle trying to install a different make/mod eng in tractor the choice's are either rebuild eng or see if you can find a good used 12-14hp eng on ebay or craigs list.
I think you are right, and I am not getting it because it doesn't run properly. I am however going to get an old Craftsman that runs great for only 150 dollars.
