studebakerjim
Hey I have a LX188 with the 17hp Kawasaki (water cooled) engine. This thing hunts terrible.
When the unit runs there is no gas at all in the fuel filter. None. And it never fills up. All linkages are free to move no binding.
All new fuel line so no leaks and still no fuel in filter. Solenoid works on the carb.
If I remove the fuel line between the pump and carb. gas will blast out of the hose from the pump side. ** then gas will fill the filter up like right now** once you attach the hose again and start the engine filter is then emptied once again.
What in the heck is going on with that? I would think there should be gas in the filter.
I looked in the carb and it was spotless. I cleaned it anyway.
Thanks
Thanks
