JD 110 snow plow?
NateJD
I have a 74 JD 110 and am looking for a snow plow. I found a guy with one but he is unsure what it came off of. He thinks either a 110 or a 210. Would they both mount the same way? Is there a way to tell by looking? If they don't match up is it possible to adapt a later plow to the 110? Thanks.
Nate
I HAD A 212 JD AND BOUGHT A BLADE FROM A LATE MODEL 110 IT MOUNTED UP JUST FINE AS THE FRONT HOLES ARE THE SAME DEMENSIONS. THE OLDER ROUND FENDER EARLY 110 PLOW MOUNTS DIFFERENT THAN THE LATER 110 112 114 MODELS AND A 210 212 214 WILL USE THE SAME BLADE
The model 43 front blade fits the square fender 110s 112s and the 200 series. The trick is getting the lift linkage with the blade.
I'm pretty sure even the larger blades for the 300 series will mount up to the frame but then you'd have to rig up a lift setup, but that's why they make linear actuators.
