Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
John Deere GX345 hydro. problem
JD50A
09-27-2011 06:59:22
My hydrostatic tranny stopped working yesterday. Won't go forward or backword, just a moaning noise. Oil level full. Any ideas what may be wrong?? Any comments appreciated. Thanks
dixon boy Rl
09-29-2011 07:47:00
 Re: John Deere GX345 hydro. problem in reply to JD50A, 09-27-2011 06:59:22
keep it simple you sure you don't have the neutral release engaged,sure sounds like it.
Heywood
09-28-2011 16:20:42
Hi,
It is probably easiest to remove the fender deck, to check it out, which is fairly easy. Easy to change, disconnect tension spring for traction drive belt, and remove nut and washer that holds pulley.
JD50A
09-27-2011 18:03:00
The belt is good, oil is full and no smell. I guess at this point I will have to look at the pully splines. I looked up there, but could not see much. Do you have to remove the deck to even see up there? If it is the pully, how hard is it to get off and replace? Thanks
Heywood
09-27-2011 09:23:35
check the pulley on the input shaft of the transmission, i"ve seen more than one that the splines have stripped out.
buickanddeere
09-27-2011 08:20:14
Drive belt ok? Cooling fins clean? Does the oil smell "bad" ?
