cadet tiller rt65
bigreddm
anybody here got the link to the shop manual for cadet tiller rt65? my tines quit turning but my wheels are still have power to them, and the shear pins in the tines are not broke. I heard a ping sound right before the tines stopped. thanks for any help...
Your tiller was made by mtd,unless there is an id tag on trans with mfg/mod# you probably won't be able to locate a repair manual for same,goto link below & click on mtd,from product list select tiller/cultivator,try to determine what yr tiller is as rt65 was made 99-11,look at assembly drawings/parts list for trans,there are 2 drive chains inside trans,one of these may have broke or possibly a shaft key,trans will have to be remove/disassembled to determine whats wrong with same,if you don't have an owners manual for same,once you determine yr/mod#,write down the mtd mod# for same goto www.mtdproducts.com & download an owners manual for same,will have trans assembly drawings/parts list in it,there are no service/repair manuals listed at mtd site for trans.
tiller
Slight error,when you get to partstree ,click on cub cadet(blue)NOT mtd and look in tiller/cultivator listings.
