Have a Grasshopper 721 gas we picked up recently, it has a stumble under load (cutting grass) once up to op temp, has an inline filter which has been replaced along with the carb being drained several times.
We cut about 6 acres so far with it at different times it has never stalled just a stumble enough to kick the pto out, followed by resuming to run properly.
My son seems to think with the choke on just a tad it does not do it = lean condition, yep checked the carb to motor gaskets & carb is tight as well.
Think this has a Koehler in it with some electric switch in the carb? we have a craftsman lawn mower w/ similar switch / selonoid that surges very similar.
What should I look at as the culprit on this grasshopper?
Thanks Gents
Thanks Gents
