wheel horse clutch plate
SLH
Can anyone tell me where I can find a aftermarket pto clutch plate for a wheel horse c-175 .THANKS
I know of no aftermarket mfg for this item(pn 94-6650)only source is toro or ebay,until a few yrs ago you could buy lining/rivets seperate for your clutch(6 1/2"-6 3/4" dia)toro in their infinite wisdom decided to go to a bonded unit & now only sells plate/lining as a unit,I don't know what toro gets for plate,several online dealers start at $59+ shipping,next best thing to do is goto ebay & search wheel horse clutch every few days & check listings(if you can wait)new/good used plates/used complete clutchs show up there or several times a yr someone will list nos lining with/without rivets,just be sure you know what you're buying as older mod wh tractors used a 6" clutch,the lining/rivets are still avail seperate for these units.
If you've got a clutch rebuilder anywhere nearby take your old lining in and look for a match. I got one with the right OD and slightly smaller ID for $13. Put it on with JB weld. I'll be pushing up daisies by the time it wears out.
