Repair
Have a guy that just got a JD 216 mower tractor & the rear motor mount bracket is broke he wants to weld it, Have any of you ever had any luck welding these brackets, They are spring steel i think. New are 150.00 & he dont want to spend that much. What do you think will it hold or will it break again. I dont think it will last.
If it is spring steel look to MG Industries MG600 welding rod. With this rod you can weld Leaf Springs and Torsion Bars. This rod is somewhat pricey.
Kent
Goto ebay & type john deere motor mount in search,several used 212/214 mounts listed,see if any match what you're looking for.
