steveinohio
My 1985 JD 214 tractor runs fine mowing grass for about 1/2 hour to an hour and suddenly starts sputtering and eventually stops running and will not restart. Removed spark plug and attached to hot wire and no spark is present. Changed coil, condenser, and ran for about 15-20 seconds and did the same thing when trying to restart-no spark. There is power from the hot wire from the points to the coil using a test light. The only thing I can think of is the points set. When taking of the points cover it appears the push pin that opens the points set is barely moving. Could I have burned points? Is the push pin an internal engine issue? This is the second time this has happened wherein it runs just fine for the previously stated amount of time and suddenly it sputters on it's own and stops and doesn't start. I have no spark at the plug even when grounding it out on the frame. My only thought now is to remove and install new points. Any information and assistance is greatly appreciated.
