Anonymous-0
Attempting to remedy leaking wheel seals on an older model (1970s) Troy-Bilt Horse tiller (case S/N 206221), I've managed to remove the wheel seals clips and shims. I see there is up/down movement of the axle, so it appears I will at least need to replace the bushings. Does this require removal of the shaft? If so, how do I remove it?
It appears the shaft has been worn by wear against the seals, so perhaps I just need to replace that while I'm this far in?
