I'm in need of a fairly short (10 " closed or less) hydraulic cylinder with only a 4-6 inch lift range. THis is for a homemade lift I'm working on, needs to only lift abour 800 lbs.
I was thinking that the lift cylinder from a lawn tractor would be about right.
I see cylinder on ebay all the time for the 118 and similar size JD mowers. Anyone know the dimension on one of these cylinders?
