JD 318 1987. Onan, oil leak bottom right by filter
mmagill
New User
I just started a good oil leak just to the right of the oil filter. Leaks really good at high idle. Should I remove the engine to did into it further. Or is there some action I can do without removing. I see sometimes the oil file assembly does loosen up, I will try to tighten, Does the right side shield come off without removing engine.
I did remove engine last year to change starter, wasn’t too bad, just time consuming.
Looking for ideas and/or recommendations.
It did start just after I added some oil .........
Thanks too all for comments
