steveinohio
I intend to install a JD fuel filter (Part #AM107314)in the fuel line from the tank to the fuel pump. In looking at this filter it appears two sizes of line (1/4 & 5/16 inch?) are at each end. I'll be using the larger size that is closes to the body of the filter. My question is do I want to remove the smaller end (1/4 inch) by cutting of sawing it off before installing it in the fuel line or install it as it is? Something tells me if I cut off the smaller end the filter or ends might crack or break. Any information regarding this is greatly appreciated. Please tell me your story if you used this filter.
