hydro drive geting hot
oldart
on a yazoo hydro drive gets hot after some time and the hydo wont pull it is an old machine what type oil shuld be used and canit be adjuster.
also is there a forum for yazoo mowers out here some were??
thanks for any help you can give.aldart
it probally uses hytran.pull the fenders off and clean the cooling fins of the dirt and grass build up.also check that the cooling fan is not broken.have you changed the filter if it has 1
