Curt from MN
Drive belt came off the other day. Replaced the primary belt, secondary belt and the drive pulley sheave. Adjusted the variator according to the operators manual. Now the tractor moves very slow. Running in 4th is like being in second. The brake pedal doesn't seem to be coming up all the way while running but every now and then it will pop up so the tractor takes off then stays down when I step on it. Is there a spring I should look at replacing or something I overlooked? Also the first 3 notches on the variator don't seem to have any resistance or change the speed then in the 5th notch the tractor will stop.
