JD LT150G Electrical issues.
Anonymous-0
Hello all! Tractor will not start with key, but will fire right up if you cross the posts on the solenoid. And as crazy as it sounds..will fire when the key is in the off position, not run. Turn it to the run position and it dies. I have replaced the safety switch under the seat, the ignition switch AND the solenoid. Still same results. Any ideas?
