Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Case 222 w/ H40 Rotary Mower Deck
bmaslowski
05-05-2010 11:16:43
I recently acquired a Case 222 tractor with an H40 (pretty sure that is the modle number) Rotary Mower Deck. It also came with a snow blower attachement. When I got the tractor as part of a deal on a house, and didn't really get a chance to ask the previous owner much about it. The snow blower was attached to it (since I got it in the winter) and I am having difficulties attachign to mower deck. I have the manuals and have the general configuration down, I just am missing all the pins and moutning hardware for the deck. Is there somewhere I can pick these up from or order from?
So far I am really pleased with the tractor, it fires right up and runs like a top. This is the first lawn tracto I've ever owned, so I am a little green on how ot handle issues with it, but I know my way around engines so I think I'll be able to take good care of it. Any help or advice would be greatly appreciated.
bmaslowski
05-07-2010 04:59:24
 Re: Case 222 w/ H40 Rotary Mower Deck in reply to bmaslowski, 05-05-2010 11:16:43
If you have the used parts that would work for me. I need all the "un-common" parts to connect the mower deck to the mule. From what I can see, this would just be the few parts for the rear mounting points. Can you please send me a price and contact me at bmaslowski@allete.com and we can work out the details. Thanks for the help.
Tom Arnold
05-08-2010 03:26:57
 Re: Case 222 w/ H40 Rotary Mower Deck in reply to bmaslowski, 05-07-2010 04:59:24
I sent you an e-mail yesterday (Friday) but have not heard back from you. Did you get it?
bmaslowski
05-06-2010 06:56:47
I found the exploded diagram - Thanks
However, when I look at page 15, I see the parts labled #43, 47 & 48.
Would I be able to get those parts from a hardware store? I will check today after work, but those seem pretty specific, escpecially #47.
Tom Arnold
05-06-2010 18:11:02
 Re: Case 222 w/ H40 Rotary Mower Deck in reply to bmaslowski, 05-06-2010 06:56:47
The parts you refer to are not common, everyday items that can be found locally. They are all made specifically for these decks.
If you send me an e-mail, you can tell me which of the following you would prefer to do.
1. Buy NEW parts. I will give you the contact info for a dealer who will sell you what you need, take your credit card info and mail the parts to you.
2. Buy USED, but servicable parts from me. I don't take credit cards but I do take Paypal and I will mail the parts to you.
Either way, I'm good with your decision. If you would like to price the new parts first, then ask me for the contact info and then decide whether new or used is how you wish to proceed.
Tom Arnold
05-06-2010 18:11:02
bmaslowski
05-06-2010 06:46:24
Thanks for the info. I did get the snow blower disconnected, and was amazed at how easily it came off. I expected to at least need a few wrences, but just the few pins, and the belt and it ws off.
I do have the Mule for the deck, and I was thinking it would be easy to find some pins to attach the deck. Hwever the 4 mounting holes on the mule and the deck do not line up. I looked at the manual and it looks like there is a special pin that goes in the back two holes to connect the two pieces. I'll take a look at the site and hopefully figure it out.
Tom Arnold
05-05-2010 14:41:30
Your 222 must be an early 70's model for it to have an H-deck. Yes, H-40 is the correct model number and it is a 38" cutting width.
If you removed the blower, then you already know that you must remove the drive belt first and then pull the spring-loaded pins on the end of the frame to allow the blower's mule bracket to tilt down and then lift off the tractor.
The deck has a similar mule bracket that attaches the exact same way. There is a steel frame that is attached to the mule bracket that extends rearward over the top of the deck and connects to the deck at four points.
Use the link below to take you to Ingersoll's home page.
Then click on "Illustrated Parts List"
Scroll way down until you see the title "Rotary Mowers" and click on the J-40 PDF. As Case made minor changes to the decks, the first letter changed from H to J, K, L, M and N but they are all very, very similar.
The exploded diagrams will help you understand what parts you do have and what parts you don't. If all you are missing are the pins, then any decent hardware store should have those in stock. They're just a plain 1/2" diameter pin with a head on one end and cross-drilled hole on the other to accept a "hairpin" or "blanket pin" type of fastener.
If you are still having problems, send me an e-mail.
Copyright © 1997-2015 Yesterday's Tractor Co.
