Here's my problem: drained hydraulic oil, cleaned screen, changed the two hoses on the lift cylinder. Now the little baby is running hot. Thought i might have a blockage somewhere so took hoses off temperature exchanger. Oil ran and looked brand new and i could also blow through the exchanger with no problem. Took the line loose at the reservoir from exchanger and oil in reservoir brown. Yes i'm running 20w50 in this. My question is does the oil actually circulate through the exchanger or is it like a passive system. i have downloaded all the parts lists and it looks as if everything is hooked up right. any ideas?
