TractorLinks.com
Fordson Tractors Discussion Forum
Re: Fordson Dexta Gear Problems
Deutz Lover
12-12-2017 17:03:02
I have reread you description of the problem. You may have a loose shifting fork. If it still drives after you put it in neutral and it is still in first gear this is very likely. When you shift to other gears it slides the loose gear temporarily back into position. There is a very high probability this is the problem. Your may also be able to feel the loose gear or the fork moving when you move the selector rail gates if this is the problem.
I am not sure what happens if one of the slide gates is loose and will have to look myself. I think the check for this to measure the distance each gate is from center at each position. If the gates don't stop at the same distance something is wrong.
Tractor Guru
12-16-2017 19:28:00
 Re: Fordson Dexta Gear Problems in reply to Deutz Lover, 12-12-2017 17:03:02
Okay! That sounds like it could be a problem also! I'll check into it! Thanks!
