Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
Re: Fordson Dexta Gear Problems
Tractor Guru
12-11-2017 19:59:56
I will try to explain the best about what it is doing! When I'm driving the tractor in 1st and I go to shift into 3rd or reverse the tractor seems like it goes into the gear, but if you let out the clutch the tractor will stall! If you put the lever into the "neutral" position the tractor will still drive in 1st! You have to shift to 2nd, and sometimes even 3rd before the tractor will go into reverse and reverse actually function! So basically you have to shift through all of the gears most times before it will actually hit reverse.
