TractorLinks.com
Fordson Tractors Discussion Forum
Re: FSM Injector pump timing
Jack Mayers
12-11-2017 07:45:00
I had the same thought but I had the flywheel off and re-installed it. It can only go on one way as the dowel pins are different diameters. I'm going to try and post some pictures to show the problem.
jdv
12-11-2017 10:43:40
 Re: FSM Injector pump timing in reply to Jack Mayers, 12-11-2017 07:45:00
If all of your marks are lined up you should be able to just turn the ip to position and bolt up. If it doesnít run right take the ip back off and rotate 180 degrees and bolt back on. I donít know on the final timing but it should be close enough to run I would think.
Jack Mayers
12-11-2017 12:44:15
 Re: FSM Injector pump timing in reply to jdv, 12-11-2017 10:43:40
I solved the problem. I found a second timing mark on the IP coupling. Got it timed.
jdv
12-11-2017 18:30:24
 Re: FSM Injector pump timing in reply to Jack Mayers, 12-11-2017 12:44:15
Good deal glad you got it, and thanks for letting us know
