TractorLinks.com
Fordson Tractors Discussion Forum
Re: Fordson Dexta Gear Problems
Deutz Lover
12-09-2017 15:06:08
That is why I photographed it. I probably spent at least an hour and a half on the internet trying to find a picture and measurements of a new one. I could not tell the exact shape and dimensions of an original one from books or vendors. I have O1 tool steel so I will probably turn the lollipops to size and then harden them. I have to figure the right profile to pin them on the shafts so they won't break. I wouldn't want pieces to get into the gears.
Tractor Guru
12-10-2017 18:31:53
 Re: Fordson Dexta Gear Problems in reply to Deutz Lover, 12-09-2017 15:06:08
Okay! So the worn shifter fix tightened the shifting up ALOT but didn't fix the stuck in gear problem! Then I noticed the "dowels" in the case that are spring loaded (Pictured) Only one of them is up and the other two are stuck! Does that have to do something with it?
Tractor Guru
12-09-2017 22:34:48
Yes metal pieces in the gears would not be good! Thanks so much!
