TractorLinks.com
Fordson Tractors Discussion Forum
Re: Fordson Dexta Gear Problems
Deutz Lover
12-04-2017 19:24:31
Tractor Guru,
Tomorrow I may be able to take pictures of what I am about to talk about. As it is said one picture worth thousand words so you may want to wait rather than puzzle over my verbal explanation. I have never posted a pic here so cross your fingers.
I removed the gear shift plate and measured the lollipop. It does approximate a ball of diameter .500 inch. The parallel slab sides are not .500 inches, but are 0.370 inch across.
I told you that the top is ground flat, but it is not quite half the half inch diameter of the projected sphere. Instead it is best to imagine grinding down the ball until the mesa or flat part has a diameter of 0.45 inch. This is measured using the what remains of the circle after the sides are ground flat or you can grind the flats later.
The distance from the the shift lever mesa to the bottom of the shift plate is pretty close to 2.00 inches.
Tractor Guru
12-05-2017 11:07:37
 Re: Fordson Dexta Gear Problems in reply to Deutz Lover, 12-04-2017 19:24:31
Again thank you!!! That should help me alot in getting it built back up!
