FMD starter
I have a fordson major that will not turn over with the starter. I think the solenoid may have failed. I bypassed everything & hooked a battery to the starter terminal. It seems the engine won?t turn past the compression. It is very difficult to turn by hand with the belt pulley. Starts quickly with a tow. Injectors were pulled to eliminate hydro lock. What can create drag on the starting system. Starter is a rebuilt. Starter motor turns by itself. There seems to be a lot of drag turning the engine. Engine runs fine.
