hughelrick
New User
So I have put an AD3 into my 62 Dexta. The original engine had filled with water down the exhaust and at some point had cracked the liner and the water jacket and is probably too much work to repair. Luckily though we had an AD3 lying around so just swapped the flywheel, rear plate and sump over made up some new pipes and got her running.
I was wondering if anyone else has done this conversion before that could help? I need some ideas of how to link up the throttle leaver to the pump since the dexta has a vacuum pipe to an inline pump and the AD3 has a rotary pump. Also what could I use for an air cleaner to manifold hose? the one for a dexta just gets crushed shut when its attached due to the longer manifold!
Any ideas welcomed!
Any ideas welcomed!
