New Fordson Tractor
I just pulled this Fordson out of a barn near Sharon Springs
NY. I'm not familiar with a tractor this old but seems to be in
great shape. Engine turns over, clutch and transmission seem
to work. Can you guys provide me with your opinions on the
shape and year.
Fordson model "F" made in the USA from 1917 until 1927 (total of about 750,000 made). Find the serial number above the manifold (usually 6 digits)to know what year it was made. See pic below.
Rear wheels appear to have little wear. Usually the lugs are worn down so that the three holes in each lug appear as half-circles. It would be very common for the gas / kerosene tank to have large rust holes in the bottom. Appears to have a generator with cutout added. There were all kinds of add-on parts available for the Fordson model "F" including some governors. A picture of the other side of the engine would show if it has a governor. Would also show if a magneto has been added. Can't tell from the pictures if the "fan belt" is the original flat belt or is a newer V- belt (it might have both).
