Hi all, new to the forum and could do with some help for a friend.
He has bought two fordsons off of the net on the strength of photos.
1:- Fordson N Registered 1942
2:- Fordson E27N ser number 985179 Registered Nov 1945
Now after a bit of research I believe the E27N serial number to be around August/September 1945 which would tie in with the registration Doc. This tractor however has no independent rear drum brakes.
There is no sign of pedals, cables or drums ever having been fitted. My question is was there ever one produced with a clutch and brake combined like the Standard n? It does have a ratchet type handbrake that can't be applied until the clutch is depressed.
The Standard N was registered in 1942 but however it is a water wash model making it produced pre 1937. The registration doc. Gives the serial number as 22F which is a number cast on the block and the transmission.
There are two numbers stamped on the block 1:- r/h side above the front of manifold SG 42105??000 and 2:- l/h centre block N 6015A. does anyone know if any of these numbers would be relevant to the production year as it would be nice to have for future reference.
Many thanks in advance for your time.
