Paper air filter for a model f
560Dennis
Location
Madison,Ohio
I want to find a late model car air filter for the model f air cleaner , I think I can find a paper air filter to adapt into the old air filter box and it would work great I think . Yu would never know it as modified to fit into tha air box.
Has anybody already done this modification .L
Ford built industrial versions of the Model F with a filter something like you want.
You may be lucky enough to find one. I have a Fordson N Industrial. (Not the one in the link) It has a very high speed gearing and also has the steering wheel scrunched up against the gas tank like a Fordson F. But it still used a water washer.
Industrial Fordson
Someone on here several years ago post that they used an air filter for saturn car in the water fill box. They said it was a good fit and all they needed was to use some gasket in a tube to hold it in place. If you do a search you should be able to find it.
Thanks , I work at an auto parts ,I will see if they will work ! I got so much money in this motor I will do whatever is necessary to make sure it has clean air going into this engine
