nothingbutdarts
New User
New here and to the Dexta, so please bear with me.
I purchased this Dexta a few weeks ago for $500.00. Not great shape but, I did take a battery and quickly bumped the engine over to see if it would turn over and not have a rusted piston or two. I saw it turn over just a few degrees and know it was OK, it still had A/freeze in it so I also knew the block was not cracked.
Got it home, drained the oils/water out of the transm. and diff. Way too much water in them but, I knew that from inspecting it before buying it. The diff. only had slight signs of rust and the only rust I could see in the transm. was the very top gear (PTO) drive gear maybe, it wasn't too bad. I then drained the eng. oil, pulled the screen, wiped out the oil pan, new filter and oil. Then I pulled the 3 injectors so as to be able to just crank the engine over and build up oil pressure before actually trying to start it.
Got oil pressure, I don't know how much because I could not find a port to tap into to install a gauge but, did leave the big nut loose on top of the oil filter housing that has the spring and ball in it. Oil started seeping out when cranking so I know it primed and had some pressure.
On to my problem, After changing fuel filter, (which was missing the spring and washer to actually hold the filter up against the top of the filter housing so it could actually filter the fuel, I believe I have that issue fixed ) I hooked the injectors to the fuel lines, left them loose to bleed the air out, cranked the engine over till all 3 were dripping fuel out at the injector connection, tightened the lines and proceded to crank it and watch the spray pattern. Well, only one had any pattern at all, the other two just seemed to dribble out.
I then pulled them off and used a pop tester, only one would pop off, at about 400 psi, the other two just leaked. I pulled apart all three, one at a time. 2 of the 3 were rusty but I won! Cleaned them all up. I managed to fine a pdf manual online but, in the section for injectors it did not give pop off pressure for the injectors. I set my three @ 1,400 psi, hooked them back up to the tractor fuel lines, bled them and only can get one to barely pop off while cranking. Now again, the injectors are out of the engine so, the engine is cranking over pretty fast. I bled and bled and still only one will barely spray yet, if you loosen the fuel lines @ the injector, they will squirt when cranking.
Did I set the pop pressure too high or do I have a Simms pump issue??? The injectors are also Simms injectors.
The spray pattern on all three after cleaning,had two spray holes on each injector which I thought was normal for the age and technology of the engine at the time.
Thank You! Kim Whitlock
