Hey All,
Looking for help on troubleshooting my Fordson Major's new clutch.
This fall I had the clutch replaced on my Fordson Major by a reputable local "old tractor" repair shop.
When I got the tractor back the clutch slipped noticeably, so I adjusted the clutch rod a few turns, until it stalled under load.
This worked well, and I have used the tractor for short to medium spells, but no really heavy work.
Two weekends ago I did a lot of dragging of stumps (already uprooted), grading, etc. By the end of 1+ hour session I could not shift at all, grinding gears. Had to turn off to shift, then limp home.
After a cool off, i re-adjusted the shift rod, and low-and behold, could shift again. Back to work. 10 minutes later, same problem. Re-adjust shift rod, back to work. etc.
As you can imagine, I quickly ran out of adjustment.
Since then I have been trying to dial in the right position, but I can't find a sweet spot.
It seems to be influenced from time of operation (or relative heat of the tractor).
Worth nothing that these weekends have had the tractor started from ~ ~15F, so a big temp swing from the starting temp and the operating temp.
Whats going on here? Is this temp related? Possible clutch wasn't adjusted right during install? Need to wear down the disc ?
Any input welcome. This 1955 runs really great, plenty of power, strong 3 pt. etc. amazing machine.
Thanks
Eben
Thanks
Eben
